Modelling Propagating 2d water waves
Old   July 7, 2011, 02:53
Default Modelling Propagating 2d water waves
ub
ubaka is on a distinguished road
Hi, im currently modelling 2d water waves propagating alomg the surface of water. Im having an issue with the wave dampening out and experiencing dispersion effects after very few wave propagations. I am usin PISO scheme with 2nd oredr aapproach for momentum. Further to this i am specify the wave inout through a velocity inlet with specified wave amplitude, wave length and celerity based around deep and shallow water criteria.
Does anybody know what the flat and wavy initialisation conditions for the open channel bc does?? When i select wavy its gives me an initial condition of the propagating wave befor i have even run the simulation. Further to thi it just amplifies the waves until the fill the whole fluid volume i set.
Any help will be grateful im kind of at a standstill with it. Thanks in advance
ubaka is offline   Reply With Quote
Old   October 18, 2012, 15:51
Default reg waves
niru
Niru is on a distinguished road
Hey Hi
I would like to model waves using fluent or CFX. Can you tell me how modelled waves?
Is there any tutorial for that?
Niru is offline   Reply With Quote
Old   October 18, 2012, 20:56
Ren/Xingyue
hilllike is on a distinguished road
Normally, for wave generation, there are a dumping zone before the open boundary, which dissipate the outgoing wave and reflected wave. In that case, Neumann boundary condition can be used.
Other researchers use a non-reflected boundary condition for open boundary without a dumping zone.
It is not difficult to find some papers on this topic, hope that can help you.
ren
hilllike is offline   Reply With Quote
wave propagation, wave tank, wavebc
Help modelling 2d propagating water waves using vof approach ubaka Main CFD Forum 1 June 28, 2011 15:24
Modelling water waves with moving wall Shane FLUENT 4 May 11, 2006 21:06
Modelling Water Waves marcus FLUENT 0 November 1, 2004 11:50
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 07:10
