MS Visual Studio
Greetings,
I have a mixed language project which I am trying to build using NMAKE. I opened the MS Visual Studio and exported the make file. I am using Compaq Digital Fortran ver and the OS is Windows XP Professional. Whenever I build the project using Visual Studio everything links with no problem, however when I try to use NMake with the exported make file I get the following error. LINK : fatal error LNK1104: cannot open file "dfor.lib" NMAKE : fatal error U1077: 'link.exe' : return code '0x450' Does anyone know how to fix this? All help is appreciated! Thanks, AK |
Re: MS Visual Studio
Build your project with visual studio and study the output window or build log file. Look for either a /LIBPATH argument to the link command or a set LIB=xxx command in the build log. Then add that to your nmake file or LIB environment variable.
The dfor.lib file is probably in a subdirectory of the fortran installation directory - you could just look for it and add that directory to the makefile (/LIBPATH:xxx option on the link line). |
