February 20, 2006, 19:42 |
About the level-set method.
hi,I am trying to use the level-set method to deal with a moving boundary problem. but It's the first time for me to use level-set method ,so I was confused at the first step.The interface in my problem is an arbitrary irregular curve, so how to give the sign distance funtion at the initial time in the whole field,or how to compute the distance from a point to an arbitray curve? I feel it is not an easy task while I can't find any discription on it in the papers I have reviewed. Maybe my problem is not a problem just because I am not familiar with the level-set method. So I appreciate any suggestion and help. Thanks a lot!!
February 21, 2006, 01:31 |
Re: About the level-set method.
try to find some important papers, J.A. Sethian, M. Sussman etc. check this out: people.tamu.edu/~yukai/
February 22, 2006, 04:13 |
thank u for ur response,Mr Yu! I have visited your homepage and found many useful links. Also I found many fascinating results in ur research. Because I am still a beginner in Level set methods, I wonder if I can send mail to u for some suggestions.
February 23, 2006, 01:39 |
no problem
November 4, 2010, 09:16 |
How to set the initial signed distance function
David
Hi!!! I also have the same problems. I am trying to use the level-set method now. I am confused at the first step for the signed distance function.The interface in my problem is an arbitrary irregular curve, Could you let me know how to give the sign distance funtion at the initial time in the whole field,or how to compute the distance from a point to an arbitray curve? Thanks.. Help me..
November 4, 2010, 14:33 |
Initialize Level Set Function
Hans Bihs
For the initialization of the level set function, try this:
1) Give all cells with Phase 1 the level set value +1 2) Give all cells with Phase 2 the level set value -1 3) Reinitialize (see Sussman,1994 and Peng,1999) Result: Level Set Function is a Signed Distance Function with the Eikonal Equation fulfilled, the zero level set gives the interface between Phase 1 and Phase 2. |
[snappyHexMesh] Boundary layer in a pipe | Clementhuon | OpenFOAM Meshing & Mesh Conversion | 6 | March 12, 2012 12:41 |
level set method for simulating detonation | Amir | Main CFD Forum | 4 | July 31, 2008 15:13 |
Problem on high density ratio in Level Set method | Kai Yan | Main CFD Forum | 10 | December 25, 2007 06:12 |
Env variable not set | gruber2 | OpenFOAM Installation | 5 | December 30, 2005 04:27 |
Free surface level set and roe | Angela | Main CFD Forum | 3 | October 25, 2002 04:12 |
