October 18, 2012, 09:17 |
flame direction
behi amini
Rep Power: 13 |
hello all,
I'm simulating the methane burning inside a big room,the burner is located on the floor at the middle of the room. the direction of flame is horizontal while that must be vertical. other thing seems correct, please help me to solve this problem. |
October 19, 2012, 05:33 |
Rep Power: 15 |
Hi, can you please explain further your case? Otherwise people might not be able to help you....
How is your burner? is it a jet flame? is it premixed? how is the geometry of the burner and the surroundings? boundary conditions you are using? are you considering buoyancy?... Post a (or some) pictures if possible. Michujo. |
October 19, 2012, 09:22 |
behi amini
Rep Power: 13 |
Thanks,
this is a room 6*5*4 m,full of air. the methane burner is 0.5*0.5 m right at the middle of the room,just methane comes out of that with 6 gr/sec mass flow rate. there is an opened door on one of the walls (1*2 m). I consider gravity and use transient solver. burner is mass inlet and door is pressure outlet, walls roof and floor are just wall. |
October 19, 2012, 17:16 |
Rep Power: 15 |
Hi, I'm assuming that methane comes out of those four cells with blue border at the bottom at the room, right? if so, the mesh is extremely coarse, you cannot pretend to compute a flame with that mesh. Is it URANS, LES, or is it a laminar flame?
Do you mean that the injection hole is 0.5m*0.5m? if so it does not seem very realistic, that is a hell of a burner! How is the true configuration? is it a case you have experimental data or is it just an academic example? I have never seen such thing before... Flames are very thin regions where large temperature and chemical species concentrations gradients are found, therefore you should refine a lot your mesh close to the flame if you want to get good results. If there's no other inlet, where does air come from? after a while, the oxygen in the room will be completely depleted and your flame with extinguish, then the methane will just come out without burning and fill the room. How do you initialise your calculation? how do you ignite it? do you model something like a spark or you just put some hot pocket at the beginning to ignite the mixture? Did you have a look at the velocity profile? Maybe the velocity is blowing the flame towards the door and that's why you get something like a horizontal flame shape, anyway, with that resolution I don't think the results are meaningful. Can you post a picture of the flame shape? (heat release field). Also, methane concentration field will be useful. Cheers, Michujo. P.S: If you have access to the book y Versteeg & Malalasekera, there's an example of a room fire CFD model, maybe you can get some ideas from it. |
October 22, 2012, 06:03 |
behi amini
Rep Power: 13 |
Hello and great thanks,
Honestly I want to simulate the pool fire ( liq fuel) so the geometry is for real situation but for liq fuel. I think it is my mistake that I don't change the geometry, I try to do it, instead of 0.5m*0.5m hole use just small hole with finer mesh, I will write to you the result asap. I use the tutorial guide: Chapter 16: Modeling Species Transport and Gaseous Combustion So according to that I don’t need any ignition although I try with ignition too. There is a door, isn't it enough for coming fresh air in? |
October 22, 2012, 06:51 |
Rep Power: 15 |
Hi. The example I pointed to before (in the book by Versteeg&Malalasekera is precisely a pool fire so you might want to have a look at it).
What you want is to define a door that enables incoming air and outgoing burnt gases, right? I don't know if such thing can be modelled (maybe "opening" boundary condition? any Fluent user here that can help us?). In the reference example they set up an air inlet and an outlet though. Good luck. Cheers, Michujo. |
October 23, 2012, 08:00 |
behi amini
Rep Power: 13 |
Hello again,
Thanks I have found the book it is useful. Also I'm trying to take door in 2 parts and run the sample again, hopefully I get air coming inside. Wishes. |
why the flame shape is quadrate? | fireman | FLUENT | 0 | February 16, 2011 11:40 |
[ICEM] Changing edge direction | la7low | ANSYS Meshing & Geometry | 2 | June 7, 2010 13:26 |
Enquiry about the flame simulation in rotary kiln | hassanelattar | FLUENT | 0 | March 25, 2009 07:41 |
premixed flame modeling problem | peiyong wang | CFX | 1 | July 18, 2008 12:02 |
Flame stabilization(DNS) | Sakis Gkatzoulis | Main CFD Forum | 0 | September 1, 2005 06:39 |
