-   -   How to analyse vacuum flow and leak detection in Autodesk Simulation CFD? (http://www.cfd-online.com/Forums/main/108663-how-analyse-vacuum-flow-leak-detection-autodesk-simulation-cfd.html)
govind October 29, 2012 18:08
Hi there,
I been trouble complete my final year project on flow analysis in a custom made mechanism, which used to hold a metal part with a notch. The mechanism using vacuum as a base to hold the work-piece, in the steel suction cup, i have sealed certain area, so that the suction area will be more stronger compare to the previous one which have leakage in the mentioned area. So that, i need to do analysis in CFD using autodesk sofware to prove that, there is no leakage occur after the improved design.
Please, urgently need a help on this.
Thank you,
Govind
govind October 31, 2012 14:10
Originally Posted by govind (Post 389195)
Hi there,
Thank you,
Govind
please...need help urgently
