source panel method
Like Tree2Likes
  • 2 Post By sbaffini
Old   January 2, 1999, 22:53
Default source panel method
joel guerrero
where can i find some info about the source panel method about wind desing and wong optimization?
Thanks, Joel Guerrero
Old   January 4, 1999, 13:08
Default Re: source panel method
John C. Chien
Books in aerodynamics, subsonic aerodynamics, theoretical aerodynamics, or fundamental aerodynamics should cover panel methods.
Old   January 13, 1999, 09:43
Ghassemi
I have the source panel code. If you want I can sell you!
Old   October 22, 2012, 10:19
Indonesia
tsd168 is on a distinguished road
I am an master student of Aerodynamics. I will work on Panel method.
I will write the code for computation, I want to ask you about the sample codes for me. Because it's first time for me to code in fortran. Any source that I can find on Internet?? or other's code?? Thank you...
tsd168 is offline   Reply With Quote
Old   October 23, 2012, 13:11
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
There are two sources online that i would strongly suggest:
1) PANAIR (A502)
http://www.pdas.com/panair.html
2)APAME
http://www.3dpanelmethod.com/home.html
They are both 3D panel methods, open and free. However these are just the source codes. If you need something more educational you can refer to:
3)http://www.dept.aoe.vt.edu/~devenpor/aoe5104/
It is full of slides and related codes. Very useful... saved my life back in the days
michujo and tsd168 like this.
sbaffini is offline   Reply With Quote
Old   November 1, 2012, 21:47
Indonesia
Thank you so much for your kindness....!!
3D PANEL METHOD Paolo Lampitella Main CFD Forum 12 August 27, 2014 11:46
Help! 3d hess smith panel method zhongyu Main CFD Forum 18 December 19, 2013 13:15
2D Field Panel Method Source Code Shukla Main CFD Forum 3 January 20, 2011 12:51
Free 3D Panel Method Daniel_Cro Main CFD Forum 2 March 25, 2009 15:08
Why use a panel method? gocarts Main CFD Forum 2 April 22, 2007 22:50
