Time step calculation
Old   March 1, 2006, 03:24
Default Time step calculation
Shashi
Dear all How can we calculate the time stem for a case involving both convection, diffusion buoyancy and combustion. Thank you
Old   March 1, 2006, 07:27
Default Re: Time step calculation
al
Physically, determining the dominant process, for example,
convection -> delta_t approx delta_x / Vel diffusion -> delta_t approx delta_x deltaX / (2 diffCoef.) ...
and so on, the smallest delta_t is which your need to use.
Mathematically, you can use stability analysis, e.g, Matrix method or Von Neumann's, but it much more difficult depending on the problem.
Thread Tools
Trackbacks are On
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 7 March 15, 2013 06:08
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 04:13
Time step size and max iterations per time step pUl| FLUENT 13 February 15, 2013 04:05
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 04:35
unsteady calcs in FLUENT Sanjay Padhiar Main CFD Forum 1 March 31, 1999 11:32
