Reynolds Number for Nozzle
Old   March 1, 2006, 22:51
Default Reynolds Number for Nozzle
Shyam
I want to compute the reynolds number for a Nozzle. The information I have at nozzle exit conditions is
Mach number M=0.90,
Velocity U=285 m/s,
Total Temp. T0=290K,
Diameter D=0.56 in,
Lip thickness 0.03 in.
Can anyone please help me in finding the Reynolds number... Can I just go by the Re based on diameter?
I want to find the first grid point distance from the wall for the grid representing the flow inside the nozzle.
Thanks, Shyam
Old   March 1, 2006, 23:31
Default Re: Reynolds Number for Nozzle
Shashi
Mr. Shyam Re=rho*U*D/Mu, So you need to know about properties of fluid i.e Mu. Assuming the flow in nozzle is quasi one dimensional calculate the Re using above expression.
Old   March 2, 2006, 04:22
Shyam
But, is it ok to assume the nozzle as quasi one-dimensional nozzle? My doubt was, in case of turbulent boundary layers, is the Re calculation still applicable, or there are other forumulations?
Old   March 2, 2006, 07:15
Jim
In order to assess whether you can assume a 1-D flow, we need more info about the shape of the nozzle. Is it conical, fluted ??? Also, assuming your talking about calculating your y+ value, why would someone come up with a turbulent wall function for a laminar flow? The method you use to calculate y+ depends on the turbulence model you are using. Getting the right y+ value is often an iterative process anyway, so make an estimate based on Re, pull out what y+ is, and adjusted it until you get something sensible.
Jim
Problem with decomposePar tool vinz OpenFOAM Pre-Processing 18 January 26, 2011 02:17
Reynolds Number and Heat transfer Coefficient panos_metal FLUENT 0 January 7, 2011 06:37
Low Reynolds Number k-epsilon formulation CFX 10.0 Chris CFX 4 December 7, 2009 23:51
Reynolds Number Matt CFX 0 February 25, 2009 05:40
