PSOR cfd code - Convergence problem
Old   March 12, 2006, 14:26
Default PSOR cfd code - Convergence problem
Taskin
hi, I have been trying to write a cfd code(in C++) to implement point successive over-relaxation method(PSOR) in a 2D duct flow with a constant pressure gradient. I have calcuated my relaxation factor many times (which is w = 1.87), however this factor leads to indeterminite results in my code. I have also written a code to implement Point Gauss Seidel scheme, which works correctyly, and I just added the following components to Point Gauss Seidel scheme: u(i,j) = (1 - w)*u(i, j)~ + w * PGauss Seidel solution
~ denotes previous iteration value
this application always diverges before it reaches 100 iterations. however solution converges to correct value when w = 1.0(which turns into Poıint Gauss Seidel)..
if anyone can help me with the problem, I'll be very glad Thanks, Taskin
Problem in k-eps turbulence code in complex geometry sontukaku Main CFD Forum 2 December 28, 2010 00:44
FSI convergence problem YY CFX 0 April 13, 2008 10:54
convergence problem in comsol anderson COMSOL 0 February 24, 2008 16:54
Continuity eq convergence problem carno FLUENT 4 February 8, 2008 04:04
convergence problem Trushar Phoenics 5 August 27, 2002 23:40
