Question about ghost cells in parallel processing
Old   March 5, 2006, 13:17
Default Question about ghost cells in parallel processing
vishwas
I have a 3-D grid in which there are 98 blocks. This grid was created using Gridgen. It will be processed using the INCA code prepared by Amtec engineering. It will be processed on one of the linux clusters at Sandia labs. I do not know any thing about the cluster and parallel processing. All I know is there a two ghost cells to be created at the boundaries of the blocks. But my question is are the ghost cells created at all the boundaries for all the blocks for parallel processing?
or
Ghost cells are created only at the boundary of the grid?
or
Ghost cells are created at all the boundaries of the blocks except for the boundaries of the grid?
Thank you
Old   March 7, 2006, 12:33
Default Re: Question about ghost cells in parallel process
vasanth
Hello friend . There are ghost cells where ever there is a boundary, weather block or grid. Solves two purposes:
1)get data from neighbouring blocks
2)impose boundary conditions
Old   March 9, 2006, 21:57
Mani
that should not be understood as a general answer, though. it very much depends on the code, and maybe vasanth's answer is true for your particular code. other codes may use ghostcells only for multiblock communication and specify boundary conditions otherwise. although a very common technique, ghostcells are not the only way to impose boundary conditions and deal with multiblock interfaces.
Old   March 12, 2006, 21:46
vasanth
So mani what are the other ways of dealing with interfaces?
Thanks
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
couple cells from different meshes in parallel sylvester OpenFOAM Programming & Development 8 September 29, 2009 04:04
Parallel Processing Set Up virgilhowardson FLUENT 1 May 11, 2009 00:54
Parallel processing ghanshyam OpenFOAM Running, Solving & CFD 21 September 22, 2008 10:52
About parallel processing in Linux tuks CFX 10 August 8, 2005 08:22
