Particle behaviour in cfd
Old   November 18, 2012, 09:51
Question Particle behaviour in cfd
Red Admiral
RedAdmiral is on a distinguished road
I have some questions concerning turbulence models and simulating the behaviour of solid particles in a fluid stream.
My fluid stream has a free stream velocity of 1 m/s, in a pipe of DN26 and a few areas where my velocity drops down to about 0,2 m/s. The speed drops are not gradually. There are also zones where recirculation is possible.
My particles have a Ø with a range from 10 to 200 µm.
I'm not sure what turbulence model is usefull to simulating the particle behaviour as accurate as possible. As a start I used a fixed turbulence velocity model. Since it's usefull for preliminary results.
The other available models are:
  • Mixing length
  • K-epsilon
  • K-omega
  • SST
But the measured behaviour in a real situation does not fit with the results I get from simulating.
Which model would you suggest?
Is the fixed turbulence viscocity not usefull in this situation, not even for preliminary results?
Also I've calculated the wall distance to my viscous layer:
0,01 mm (pipe is DN26).
Now I wonder if it's necessary to simulate the friction with near wall meshing or a wall function in this kind of model.
I've used slip wall as a start. Because my fluid is water and the viscocity is quite low.
Is the behaviour of the viscous - and buffer layer on the turbulent layer to important to ignore?
I'm quite new to modeling turbulent flow but eager to learn.
If someone has other good suggestions or tips.
I'll be glad to read them
RedAdmiral is offline   Reply With Quote
STAR-Works : Mainstream CAD with CFD CD adapco Group Marketing Siemens 0 February 13, 2002 12:23
ASME CFD Symposium, Atlanta, July 2001 Chris R. Kleijn Main CFD Forum 0 September 13, 2000 04:48
ASME CFD Symposium, Atlanta, July 2001 Chris R. Kleijn Main CFD Forum 0 August 21, 2000 04:49
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 12, 1999 23:27
public CFD Code development Heinz Wilkening Main CFD Forum 38 March 5, 1999 11:44
