Kiva sie errors
Old   March 5, 2006, 06:54
Default Kiva sie errors
Ravi Kiran
Hi friend I am working on Kiva
I am getting error at strat of combustion saying sie becoming negative largely
can anyone suggest remedy
thank you Ravi Kiran
Old   March 10, 2006, 19:49
Default Re: Kiva sie errors
zaki
Hi Ravi,
I had the same problem like you. I suppose the negative sie could be resulted from inappropriate input values. In my case (turbulent diffusion flames inside furnace), I wrongly specified the initial tke and epsilon, since I just followed what was written in the KIVA user's guidance. What was written there about the appropriate initial values should be carefully understood. So, in encountering the problem, I tried to use trial-and-error method on the initial values of tke and eps in every execution of the code until I got a decent result. So, please refer back to any change of the input data or even of the code itself that you made.
I have no specific suggestion or clue on any remedy, since the remedy surely depends on what kind of problem you are working on. But generally speaking, you have to be really really really meticulous in dealing with large code like KIVA.
Wish you best of luck.
zk
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
