March 12, 2006, 14:26 |
PSOR cfd code - Convergence problem
hi, I have been trying to write a cfd code(in C++) to implement point successive over-relaxation method(PSOR) in a 2D duct flow with a constant pressure gradient. I have calcuated my relaxation factor many times (which is w = 1.87), however this factor leads to indeterminite results in my code. I have also written a code to implement Point Gauss Seidel scheme, which works correctyly, and I just added the following components to Point Gauss Seidel scheme: u(i,j) = (1 - w)*u(i, j)~ + w * PGauss Seidel solution
~ denotes previous iteration value this application always diverges before it reaches 100 iterations. however solution converges to correct value when w = 1.0(which turns into Poıint Gauss Seidel).. if anyone can help me with the problem, I'll be very glad Thanks, Taskin |
Problem in k-eps turbulence code in complex geometry | sontukaku | Main CFD Forum | 2 | December 28, 2010 00:44 |
FSI convergence problem | YY | CFX | 0 | April 13, 2008 10:54 |
convergence problem in comsol | anderson | COMSOL | 0 | February 24, 2008 16:54 |
Continuity eq convergence problem | carno | FLUENT | 4 | February 8, 2008 04:04 |
convergence problem | Trushar | Phoenics | 5 | August 27, 2002 23:40 |
