Solution diverges
Like Tree1Likes
  • 1 Post By cdegroot
Old   November 30, 2012, 06:54
Question Solution diverges
Anna Tian's Avatar
Meimei Wang
Anna Tian is on a distinguished road
May I ask what does it mean by 'solution has diverged'? Usually how to avoid this?
Thanks.
Best regards,
Meimei
Anna Tian is offline   Reply With Quote
Old   November 30, 2012, 07:20
cdegroot's Avatar
Chris DeGroot
cdegroot is on a distinguished road
If a solution diverges that means the iterative process that is supposed to drive the initial guess of the solution to the actual solution has failed and instead the solution has been driven further away from the actual solution.
There are many things that could cause this including inconsistent specification of physics/boundary conditions or not applying enough relaxation to stabilize the numerical method. Generally it means your problem is ill-posed in some way or the iterative method is unstable in some way.
Crank-Shaft likes this.
cdegroot is offline   Reply With Quote
Old   December 3, 2012, 23:48
kullimanali
arunbaghel is on a distinguished road
Originally Posted by Anna Tian View Post
Thanks.
this means ur solution is not correct, convergence means there is acceptable difference between previous and current solution, it depends upon how much u have set residual and divergence means there is large difference the residual
arunbaghel is offline   Reply With Quote
interFoam solution tolerances mgdenno OpenFOAM 4 September 13, 2011 12:58
Naca 0012 (compressible and inviscid) flow convergence problem bipulsaha FLUENT 1 July 6, 2011 07:51
Transient, initial variables from a previous solution nakor FloEFD, FloWorks & FloTHERM 0 April 22, 2011 04:34
solution diverges varun Siemens 1 January 11, 2005 03:10
Discussion about Mesh independant solution Seb Main CFD Forum 13 May 22, 2001 13:37
