Patankar's cyclic TDMA
Old   March 19, 2006, 19:55
Default Patankar's cyclic TDMA
George
Hi everybody! Does anybody has the subroutine of the cyclic TDMA of Patankar?Can you send me it? Thank you in advance
Old   March 20, 2006, 20:17
Default Re: Patankar's cyclic TDMA
George
Or any other subroutine concerning cyclic or periodic boundary conditions...
Old   March 20, 2006, 22:40
Manish
Hi, If it is TriaDiagonalMatrixAlgoritm, you can find it Numerical Recipies in FORTRAN or Numerical Recipies in C.
Old   March 21, 2006, 02:55
ali mottalea
i have a TDMA subroutine. but what you mean by cyclic. if it is a slice from axisymetric 360 degrees. please explain it.
Old   March 21, 2006, 11:49
George
Yes, it is a TriaDiagonalMatrixAlgoritm.But if there are cyclic or periodic boundary conditions in the flow, then there is a different version.I am trying to change it, but I have some problems. For Ali Mottalea: It is not axisymmetric, it is full 3D cylindrical flow.
Old   March 21, 2006, 14:08
ali mottalea
ok. then as i know your coordinate system is cylindrical and in teta=0 and 360 you have cyclic condition. is it true?
Old   March 21, 2006, 19:10
George
Yes. And you must change a little bit the original TDMA, so that you can take into consideration this difference in the usual boundary conditions
Old   March 22, 2006, 10:18
Enrico
For symmetric tridiagonal matrices (diagonally dominant) you can give a look here:
http://www-dinma.units.it/nirftc/research/cyctrid/
Cyclic bc. and overlapGgi Pekka OpenFOAM 12 February 15, 2012 07:10
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 maverick OpenFOAM Meshing & Mesh Conversion 2 June 18, 2011 04:36
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 17:08
Cyclic patches and parallel postprocessing problems askjak OpenFOAM Bugs 18 October 27, 2010 03:35
[snappyHexMesh] snappyHexMesh with cyclic patches? Axel_T OpenFOAM Meshing & Mesh Conversion 1 October 12, 2010 10:03
