-   -   Solving Backstep Flow model using Excel (http://www.cfd-online.com/Forums/main/110365-solving-backstep-flow-model-using-excel.html)
sjwon1991 December 9, 2012 23:35
1 Attachment(s)
Hi, I'm college student in Yonsei Univ, South Korea
My Professor gave us project to solving backstep flow model using Excel.
But I don't know how to make boundary conditions about this time...
Exactly about du/dx=0 using streamline and vorticity
I hope there is someone who can help me
mettler December 10, 2012 09:51
first you need to transform the equations into streamfunction/vorticity equations. Using Excel and finite difference
Guess a value for Streamfunction and vorticity (=0).
Using the entrance velocity get your new vorticity values.
Get the new streamfunction values from the new vorticity values.
Get the new velocities from the new stream functions
use the new velocities to get the new vorticity..etc etc
The hardest part is setting up the BCs for the vorticities at the corners.
sjwon1991 December 10, 2012 14:44
Yeah..
Yeah.. Actually, I want to know about BCs,
Exactly about Right side, known as du/dx = 0
I set up the equation as Central Difference Method to get 2nd order Truncation Error...
And there is another problem about this problem..
u and v is defined as function of psi, so I setted u as 2, 1.875, etc...
but most of student setted it as 1, 0.875 etc...
I want to know about this reason..
mettler December 10, 2012 14:52
what I think your case of du/dx means is that at the exit the velocity is no longer changing in the X-direction. that lets you set a BC at the exit, since U@x = U@x+1. Your grid should be able to get the U@x, but the U@x+1 can't be found, so you assume that the flow is fully developed in order to get that value.
you want U=1 to be freestream velocity, since everything should be dimensionless. You can also assume a uniform flow field coming in, so U=1 at the entire left (flow from left to right), but then your BC to get from the no-slip to the free stream can get a little tricky, but it is not impossible to figure out
