Help with KIVA
Old   March 21, 2006, 12:51
Default Help with KIVA
Phil
I am new to KIVA and appreciate if anyone could provide assistance. We are trying to perform simulations for CI engine. However, ignition did not occur. While I adjusted cf1 in itape5 (increasing it), combustion seems to occur, however, the pressure and heat release are both now too big. Anyone can help me on this?
Thanks a lot.
Old   March 22, 2006, 07:57
Default Re: Help with KIVA
Tomislav
Could be many things. For example too small fuel quantity to notice the effects, or too high tcut or tcute in itape5.
Old   March 24, 2006, 01:55
tak
hello phil
I am also using kiva for spark ignition engines, and for combsution play with tcut and tcute in itape5
i have one question, for grid generation are you using k3prep (kiva3v rel2 )or some other pre processor code, because i am facing many problems for generating grid with four valve pentroof engine ( i tried to improve the grid density to the 4valve engine example , i am getting inverted cells) can you please suggest me the better way to generate grids using k3prep
Old   March 25, 2006, 02:40
ali mottalea
if you get inverted cell when running kiva main program or k3prep?
Old   March 25, 2006, 11:58
tak
I am getting inverted cells (otape 11)during executing k3prep for grid file otape17.
Old   March 26, 2006, 10:40
ali mottalea
if i have your iprep file i probably could help you.
Old   October 30, 2010, 14:08
Default deciding value for 'NBO'
shahid
shahidimran is on a distinguished road
i am a beginner with kiva3v.
will you please guide me how can we decide the value of NBO for a block and how to specify i,j..x,y for these values
hope you will reply
shahidimran is offline   Reply With Quote
Old   November 3, 2013, 04:27
Default otape
mamalili is on a distinguished road
hi
i am a beginner of openFOAm
and search for a case for research
can you offer me a link so that i can download an otape of it to convert in openFOAM, please?
tank you very much
mamalili is offline   Reply With Quote
Thread Tools
Trackbacks are On
About Kiva 4 installation. fahdme OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 7 November 8, 2013 15:01
Kiva 4 vjay CD-adapco 8 July 13, 2013 17:53
mesh converter in KIVA 4 DaIN Main CFD Forum 0 June 7, 2010 12:54
kiva 4 installation fahdme OpenFOAM Installation 3 May 25, 2010 17:54
PDF - conserved scalar approach in KIVA vega Main CFD Forum 0 July 5, 2005 02:49
