Question on moving mesh, mesh velocity is really small!
Old   December 14, 2012, 11:15
Default Question on moving mesh, mesh velocity is really small!
Jack
ripperjack is on a distinguished road
Hi guys,
I am coding a finite volume code to calculate the unsteady pressure for a moving airfoil. I used Roe scheme, and I am really confused with the moving mesh method.
I calculate the mesh moving velocity and it is really small (V_g=1m/s), and the flow velocity V is larger than 200m/s. And it seems that the mesh moving velocity has no influence on the solution.
As I understand, for Roe scheme, the cell surface flux for moving mesh is nearly the same as for stationary mesh, the only different is that the velocity V in eigenvalue for moving mesh is replaced by V_r. (V_r=V-V_g) . However, since V_g is very small, it seems that it has limited influence on the solution.
Can you guys who had the experience in moving mesh help me? Thanks!
ripperjack is offline   Reply With Quote
Old   April 27, 2014, 12:03
orxan.shibli is on a distinguished road
Not only eigenvalues but flux vector changes, too. Considering 3D flux in normal direction:
F_0 = \rho (u_n - u_b) \\
F_1 = \rho (u_n - u_b) u + p n_x \\
F_2 = \rho (u_n - u_b) v + p n_y \\
F_3 = \rho (u_n - u_b) w + p n_z \\
F_4 = (u_n - u_b) E + p u_n \\
orxan.shibli is offline   Reply With Quote
Old   April 28, 2014, 13:37
levivad is on a distinguished road
from a physics stand point, it makes sense that if the boundary moves slowly relative to the flow velocity it will be insignificant ( unless there's some special case). This is true until the geometry changes enough to impact the flow.
It might be considered quasi-static.
levivad is offline   Reply With Quote
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? karkar OpenFOAM Meshing & Mesh Conversion 0 July 4, 2012 06:54
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
