are there any advantages of writing codes than simulation in fluent?
Like Tree16Likes
Old   December 20, 2012, 14:18
Chris DeGroot
cdegroot is on a distinguished road
Good input for sure. I think being able to write code should be considered as an asset when looking for a CFD position (because of the knowledge of theory it requires), but certainly isn't the only thing that's necessary. I probably wouldn't hire someone for a position using commercial codes if coding is the ONLY thing they have done in CFD, for the reasons you mentioned. I think a combination of coding and using other codes is ideal. I think someone is more adaptable to other codes if they have experienced coding themselves.
Martin Hegedus likes this.
cdegroot is offline   Reply With Quote
Old   December 26, 2012, 12:02
Smile
  #22
Richard Ren
wtffqbpl is on a distinguished road
do what you want to do, and you can spend some time on cfl3d code, it can give you a lot knowledges.
wtffqbpl is offline   Reply With Quote
Old   January 6, 2013, 00:11
Martin Hegedus
Martin Hegedus is on a distinguished road
Richard, CFD3D is restricted. http://cfl3d.larc.nasa.gov/ Since your location reads "China" I assume you do not have permission to use CFL3D.
Edit: I assume the source code is marked as restricted and if you have read this you would know it.
Martin Hegedus is offline   Reply With Quote
Old   January 6, 2013, 01:51
Richard Ren
[QUOTE=Martin Hegedus;400267]Richard, CFD3D is restricted. http://cfl3d.larc.nasa.gov/ Since your location reads "China" I assume you do not have permission to use CFL3D.
Edit: I assume the source code is marked as restricted and if you have read this you would know it.[/QUOTE
although cfl3d is very famous, i haven't read it. there are some open code in china, such as opencfd. and it's very famous in china. have you read it? everyone can read it, (^_^)
Thread Tools
Trackbacks are On
IC engine simulation tutorial by FLUENT yash FLUENT 4 April 6, 2015 19:44
Chemical Equilibrium Simulation using Fluent enigma ANSYS 2 October 27, 2011 08:02
Combustion SImulation in Fluent santhosh1987 FLUENT 1 May 14, 2010 16:03
Combustion SImulation in Fluent santhosh1987 FLUENT 0 May 14, 2010 10:32
Why is my fluent simulation giving Cp values above 1??? wils Main CFD Forum 3 March 26, 2010 10:12
