March 25, 2006, 22:38 |
some problem about the FEM programming
Hi:
i want to develop a FEM code for the two dimensional lid driven problem in a rectangular region , i use 4 nodes quadrilateral element. FEM need a Galenkin projection, and one must to evalute the integral. it need to use the Gauss quadrature, but i do not have the value at the gauss point ,how should i do? can i use a conventional trapezodial rule? regards. |
March 26, 2006, 11:28 |
Re: some problem about the FEM programming
why don't you have the values at the gauss points? your 4-node quadrilateral element is defined by a set of shape functions that should allow you to evaluate the function on any point in space, based on the function values at the four nodes. if you use the trapezoidal rule, or any other arbitrary rule, you will most likely create inconsistencies within your discretization method. use the shape functions.
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 19:42 |
CUDA programming problem | ztdep | Main CFD Forum | 0 | January 26, 2011 05:24 |
Can I solve this problem by Fluent? | Kai_kc | FLUENT | 1 | October 27, 2010 05:29 |
How good is CFD? | kai | Main CFD Forum | 39 | April 7, 2000 12:48 |
