Viscosity
Old   March 29, 2006, 00:15
Default Viscosity
Muhamad Usman
Defination of viscosty ,According to Newton's law of viscosity is,
viscosity= (Shear Stress)/(velocity gradient) It shows that for a liquid of high viscosity (like honey) velocity gradient will be very low.Is it actual situation?.I can understand this?
Old   March 29, 2006, 04:20
Default Re: Viscosity
ramp
Hi !!
All the liquids do not follow the Newton's law of viscosity and so known as non-Newtonian liquids. Since, most of the highly viscous fluid are non-Newtonian fluids, the velocity gradient will depend on the fluid type, whether its shear-thinning. shear-thickening, viscoelastic, time-dependent or independent etc...
There are various text books available related to the rheology of fluids, including the following
[1] Barnes, H.A., Hutton, J.F. and Walters, K. (1989). An Introduction to Rheology. Elsevier, Amsterdam.
[2] Carreau, P.J., De Kee, D. and Chhabra, R.P. (1997). Rheology of Polymeric Systems. Hanser-Gardner: Munich, Germany.
[3] Chhabra, R.P. and Richardson, J.F. (1999). Non-Newtonian Flow in the Process Industries: Fundamentals and Engineering Applications. Butterworth-Heinemann, Oxford.
[4] Coussot, P. (2005). Rheometry of Pastes, Suspensions and Granular Materials: Applications in Industry and Environment. John Wiley & Sons, Inc. New York.
[5] Skelland, A.H.P. (1967). Non-Newtonian Flow and Heat Transfer. Wiley, New York, USA.
Best regards.... Ramp
Eulerian Modeling: Frictional Viscosity Help meangreen FLUENT 1 January 25, 2018 15:13
Power - Law Viscosity Model for Polymers NickolasPl OpenFOAM 2 August 12, 2011 08:26
Turbulence viscosity limited Madhukar Rapaka FLUENT 0 June 26, 2006 03:17
kinematic viscosity at diff temperatures,pressures Mecobio Main CFD Forum 0 November 7, 2005 12:55
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
