Linear Algebra Package for general sparse matrices
Old   December 18, 2012, 00:42
Question Linear Algebra Package for general sparse matrices
Prapanch Nair
prapanj is on a distinguished road
I am programming a particle based method for flow problems. It uses linked list data structure. It solves a poisson equation and since the particles can have arbitrary positions, the matrix need not be banded. So far I have been using BiCGSTAB which I programmed myself. Since the data structure is linked list, I find my code inefficient. I am considering temporarily writing to arrays to solve the poisson equations and also use a Linear Algebra package. I would like to know what Linear Algebra package may be apt. I searched through LAPACK and similar websites and they mention that they exclude general sparse matrices in their features. Considering this, please suggest me some package that would be easy to use and doesn't have restrictions. I program in C and would like to know about packages that are in C.
prapanj is offline   Reply With Quote
Old   December 18, 2012, 02:45
Praveen. C
praveen is on a distinguished road
PETSC and TRILINOS are the most comprehensive linear algebra packages available today.
praveen is offline   Reply With Quote
Old   December 18, 2012, 07:25
cdegroot's Avatar
Chris DeGroot
cdegroot is on a distinguished road
I use PETSc in my code and I have been happy with it. It has many solver options and is pretty straightforward to use.
cdegroot is offline   Reply With Quote
Old   January 2, 2013, 06:58
ignatius is on a distinguished road
I have used both, Petsc and Trilinos, petsc is easier to install. On the other hand I know trilinos has some features to handle dense matrices.
With respect to petsc, here there is a thread about it, in some other website
http://scicomp.stackexchange.com/que...dense-matrices
Anyway, how did you get a dense matrix if you are solving a poisson equation?
I recommend you to first try with petsc and if it is not good enough, make an extra effort and install trilinos.
regards,
I.
ignatius is offline   Reply With Quote
bicgstab, lapack, linear algebra, poisson equation, solver
A turbulent test case for rhoCentralFoam immortality OpenFOAM Running, Solving & CFD 13 April 20, 2014 06:32
Extend Project 1.6-ext Binary Release for Mac OS X hjasak OpenFOAM Announcements from Other Sources 26 November 5, 2013 16:50
Problem? with Installation of OpenFOAM 2.1.0 on to Ubuntu 10.4.4 VirtualBox Stubby OpenFOAM Installation 8 March 5, 2012 15:12
solution diverges when linear upwind interpolation scheme is used subash OpenFOAM 0 May 29, 2010 01:23
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
