Mean Strain rate
Old   January 10, 2013, 07:53
Default Mean Strain rate
Michael Rembe
rembe is on a distinguished road
I'm not an expert in fluid mechanics. In the SMAGORINSKY-model I need the square root of Sij*Sij. I'm a little confused about the different notations. What is the defference between the mean strain rate defined as:
and the mean strain rate defined as:
Sij=0.5*(dUi/dxj+dUj/dxi)
Some times I can read:
S=sqrt((dUi/dxj)^2+(dUj/dxi)^2)
I would be very grateful for a short explanation.
Thank you very much!
Michael
rembe is offline   Reply With Quote
Old   January 14, 2013, 03:11
Rami Ben-Zvi
Rami is on a distinguished road
Hi Michael,
That's simply tensor algebra (using the sum convention).
If you use the definition Sij=0.5*(dUi/dxj+dUj/dxi) , substitute it in s^2 =Sij*Sij and sum over i and j, you'l get the result
from the other expression,
you get
S^2=Ui,jUi,j+ Uj,iUj,i = 4SijSij - 2Ui,jUj,i
so it is different due to the last term.
Rami is offline   Reply With Quote
strain rate in UDF Paulina FLUENT 11 November 20, 2014 03:06
Shear Strain Rate Dave442 Main CFD Forum 5 October 25, 2013 04:08
strain rate magnitude ahmadbakri STAR-CCM+ 1 June 3, 2010 13:03
Strain rate. MM? Main CFD Forum 1 February 15, 2006 08:55
strain rate at arbitrary position in a cell K. Kevala FLUENT 0 February 4, 2004 17:14
