flow around a cylinder
I am searching data of a flow around a cylinder (for comparison). Do you know any good reference? Thanks. |
Re: flow around a cylinder
Hi !! I hope the following reference will provide you all the data...
[1] Ahmad, R.A., 1996, Steady-state numerical solution of the Navier-Stokes and energy equations around a horizontal cylinder at moderate Reynolds numbers from 100 to 500, Heat Transfer Engg., 17: 31-81. [2] Chakraborty, J., Verma, N. and Chhabra, R. P., 2004, Wall effects in the flow past a circular cylinder in a plane channel: a numerical study, Chem. Engng. Processing, 43: 1529-1537. [3] Coutanceau, M. and Bouard, R., 1977, Experimental determination of the main features of the viscous flow in the wake of a circular cylinder in uniform translation. Part 1: Steady flow, J. Fluid Mech., 79: 231-256. [4] Coutanceau, M. and Defaye, J.-R., 1991 Circular cylinder wake configurations: a flow visualization survey, Appl. Mech. Rev., 44: 255-305. [5] D'Alessio, S. J. D. and Dennis, S. C. R., 1994, A vorticity model for viscous flow past a cylinder, Comp. Fluids, 23: 279-293. [6] Dennis, S. C. R. and Chang, G.-Z., 1970, Numerical solutions for steady flow past a circular cylinder at Reynolds number up to 100, J. Fluid Mech., 42: 471-489. [7] Dennis, S. C. R. and Hudson, J. D., 1995, An $h^4$ accurate vorticity-velocity formulation for calculating flow past circular cylinder, Int. J. Numer. Meth. Fluids, 21: 489-497. [8]Dennis, S. C. R., Hudson, J. D. and Smith, N., 1968, Steady laminar forced convection from a circular cylinder at low Reynolds numbers, Phys. Fluids, 11: 933-940. [9]Fornberg, B., 1980, A numerical study of steady viscous flow past a circular cylinder, J. Fluid Mech., 98: 819-855. [10] Fornberg, B., 1985, Steady viscous flow past a circular cylinder up to Reynolds number 600, J. Comp. Phys., 61: 297-320. [11] Ding, H., Shu, C., Yeo, K. S. and Xu, D., 2004, Simulations of incompressible viscous flows past a circular cylinder by hybrid FD scheme and meshless least square-based finite difference scheme, Comput. Methods Appl. Mech. Engng., 193: 727-744. [12] Hamielec, A. E. and Raal, J. D., 1969, Numerical studies of viscous flow around circular cylinders, Phys. Fluids, 12: 11-17. [13] Kawaguti, M. and Jain, P., 1966, Numerical study of a viscous flow past a circular cylinder, J. Phys. Soc. Jpn., 21: 2055-2062. [14] Sucker, D. and Brauer, H., 1975, Fluiddynamik bie quer angestromten Zylindern, Warme- and Stoffubertagaung, 8: 149-158. [15] Takami, H. and Keller, H. B., 1969, Steady two-dimensional viscous flow of an incompressible fluid past a circular cylinder, High-Speed Computing in Fluid Dynamics The Phys. Fluids Supplement II, 12: 51-56. best regards..... Ramp |
I can also add M.M. Zdravkovich, Flow Around Circular Cylinders, Oxford University Press, 2003
[1] M.M. Zdravkovich, Flow Around Circular Cylinders, Vol. 1 Fundamentals, Oxford University Press, 1997
[2] M.M. Zdravkovich, Flow Around Circular Cylinders, Vol. 2 Applications, Oxford University Press, 2003 |
Thanks a lot. I have already found some of the posted titles.
Unfortunately the book "Flow Around Circular Cylinders" is very expensive!!! I am actually looking for papers or summaries to investigate the influence of different turbulence models. Unfortunately, I didn't find any inforamtion about it in the publications (Journal of Fluid Mechanics). Even velocities, geometrical data, temperatures are rare. So, I would appreciate, if you have further ideas for me. |
Hi !! May be the following (or cross references) can give you something:
[1] Norberg, C. (2003). Fluctuating lift on a circular cylinder: Review and new measurements, Journal of Fluids and Structures 17 (1), pp. 57-96 29 [2] Norberg, C. (2001). Flow around a circular cylinder: Aspects of fluctuating lift, Journal of Fluids and Structures 15 (3-4), pp. 459-469 [3]Norberg, C. (1994). Experimental investigation of the flow around a circular cylinder: influence of aspect ratio, Journal of Fluid Mechanics 258, pp. 287-316 96 [4] Norberg, C., Sunden, B. J. (1987). Turbulence and Reynolds number effects on the flow and fluid forces on a single cylinder in cross flow, FLUIDS & STRUCT. 1 (3 , Jul. 1987), pp. 337-357 9 [5] Norberg, C. (1985). INTERACTION BETWEEN FREESTREAM TURBULENCE AND VORTEX SHEDDING FOR A SINGLE TUBE IN CROSS-FLOW, Journal of Wind Engineering and Industrial Aerodynamics 23 (1-3), pp. 501-514 Best regards.... Ramp |
it sounds quite promising - but I am not sure if I will be able to access the Journals. If it isn't too much work for you it would be fantastic if you could send them to me by mail (mailto: pxyz@hotmail.com). Best regards...pxyz |
Hi !!
Find it in your mailbox... Best regards.... ramp |
Hi ramp,
thanks a lot!!!! I just found your mail, that's why I didn't read the papers --> but I will. Best regards, pxyz |
Hi Mayo....
Forwarded these papers, find in your mailbox Best regards... Ramp |
Hey can any one from you 3 persons (Ramp, Mayo & Pxyz) forward this papers to me?
My email address is jugal44j@gmail.com I am also working on same topic"Flow around cylinder". I need some data to compare. Thanks in Advance.... |
3D flow around a rectangular cylinder
can you guys send me some copies. im working on 3D flow around a rectangular cylinder. pls send it to olaworesly@yahoo.com
I would be grateful for some copies as well since I am looking into similar phenomena!!!
Thank you in advance, A.D.E adecfd@gmail.com |
