CFX-particle flow
Old   August 2, 1999, 07:08
Default CFX-particle flow
Eve Chapper
I'm using CFX and in the command file I would like to add 3-micrometer particles (of yeast) into a flow stream of water. I've tried following the example in the book but I'm extremely lost. Can anyone out there please help.
Thanks Eve
Old   August 2, 1999, 08:53
Default Re: CFX-particle flow
Patrick Godon
Hi there,
I am not working with CFX and I have no clue what is in that software.
However, I can try to help with particles in the flow. This is called a two-phase flow. You need to solve for the particle some additional equations where the force that act on a particle is a function of the velocity difference between the flow and the particle. THe equations might have also a different form depending on the density of the particles (if their density is close to the density of the flow then the euqations are not simplified).
In the simplest case (the Epstein regime) the particles are just dragged in the flow. There is a drag parameter in the problem with two limiting cases. If the drag is very small then the particles move almost on their own. If the drag is very large, then the particles move with the flow like tracers.
I hope this helps,
and I hope there is somebody there or here to help you with the CFX part of it.
Patrick
Old   August 3, 1999, 05:29
yi
Hi, the following is the relevant part of a command file for particle tracking. You can change it accordingly and add it into your command file.
Hope that it will help.
Yi ----------------------------------------------------------
>>CFX4 #CALC
NP=100; /* number of particles */ #ENDCALC
>>OPTIONS
PARTICLE TRANSPORT
>>MODEL DATA
>>PARTICLE TRANSPORT MODEL
>>MODEL CHARACTERISTICS
NUMBER OF PARTICLES 100
NUMBER OF ITERATIONS 1
CROSS SECTION FACTOR 1.0000E+00
SURFACE AREA FACTOR 1.0000E+00
DROPS
>>INTEGRATION PARAMETERS
TIME LIMIT 5.0000E+00
COEFFICIENT OF RESTITUTION 0.0000E+00
>>PARTICLE PROPERTIES
BASE PARTICLE DENSITY 1.0000E+03
>>MODEL BOUNDARY CONDITIONS
>>PARTICLE TRANSPORT BOUNDARY CONDITIONS
POSITIONS IN X DIRECTION #NP*1.0e-4
POSITIONS IN Y DIRECTION #NP*0.130
POSITIONS IN Z DIRECTION #NP*3.0
INITIAL PARTICLE DIAMETERS #NP*3.0e-6
PARTICLE MASS FLOW RATES #NP*1.0E-6
U VELOCITY #NP*6.0
V VELOCITY #NP*0.0
W VELOCITY #NP*0.0
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
specify boundary condition type in particle tracking in order to trace flow filed payam_IUST FLUENT 1 October 15, 2009 17:16
turbulence model in CFX, seperated flow F. Bhuiyan CFX 3 August 9, 2009 23:28
compressible flow in CFX! Ihsan CFX 9 January 15, 2008 18:50
particle, parcel and mass flow rate balance flybird FLUENT 0 May 24, 2007 10:44
