Question about shifting turbulence model from K-Omega to SSG Reynolds stress |
November 3, 2012, 14:03 |
Meimei Wang
Rep Power: 15 |
Hi
I'm shifting the turbulence modeling of my simulation from K-Omega to SSG Reynolds stress. The grid independence study result works well for my K-Omega simulation. May I ask do I need to do the grid independence study again? (Only because I change my turbulence model) Thank you very much.
Best regards, Meimei |
January 20, 2013, 11:30 |
#2 | |
Meimei Wang
Rep Power: 15 |
Could someone answer me this question? Thanks!
January 20, 2013, 12:36 |
Chris DeGroot
Rep Power: 17 |
I would check grid independence again. When you check grid independence you are trying to determine if the solution that you obtained for your governing equations is sufficiently resolved by the grid that you used. Since the turbulence equations that you are solving are different, it can't be guaranteed that the same grid will do as good of a job resolving the solution. That being said, it is fairly likely that the same grid is fine since the solution of the turbulence equations influence the flow solution indirectly. However, it is good practice to always check.
SSG Reynolds Stress Turbulent Source on Boundary | st268 | CFX | 3 | September 11, 2012 07:24 |
SSG Reynolds Turbulence Model | Georges | CFX | 1 | February 28, 2007 16:15 |
Convergence problems with SSG turbulence model | Ram | CFX | 1 | June 19, 2006 10:08 |
Questions about the Reynolds stress model | empirer2002 | Main CFD Forum | 1 | January 5, 2006 07:37 |
Reynolds stress Model | Chimenti Martín | Main CFD Forum | 5 | November 21, 2001 13:22 |
