How to decide the number of grid lines in boundary layer
Like Tree2Likes
  • 1 Post By Anna Tian
Old   January 20, 2013, 17:21
Question How to decide the number of grid lines in boundary layer
Anna Tian's Avatar
Meimei Wang
Anna Tian is on a distinguished road
May I ask how to decide how many grid lines(at the direction proportional to the wall) do I need(to resolve boundary layer well)?
Of course grid independence study is always good practice. But I always need a first guess of this number to have my first grids before the grid independence study. Thank you very much.
immortality likes this.
Best regards,
Meimei
Anna Tian is offline   Reply With Quote
Old   January 21, 2013, 03:52
cfdnewbie
cfdnewbie is on a distinguished road
That depends on the order of your scheme and on the type of flow you are considering. Impossible to answer in general....
cfdnewbie is offline   Reply With Quote
Old   January 24, 2013, 17:08
Question
Anna Tian's Avatar
Meimei Wang
Could you please recommend any paper about this?
Best regards,
Meimei
Old   January 24, 2013, 22:25
agd
agd is on a distinguished road
If you are performing a RANS or URANS simulation the standard approach is to settle on the distance of the first point off the wall based on an acceptable y+ value, and then keep any grid stretching ratio below 1.2. The resulting simulation should always be reviewed after the fact to ensure that the actual value of y+ is still acceptable and the boundary layer is well-resolved.
agd is offline   Reply With Quote
Old   January 25, 2013, 05:04
venki
venkateshaero is on a distinguished road
After running problem in solver. you will get actual value of Y+ . before running also we can calculate by Y+ estimatation calculater in CFD online(Rough). based on calculation you can find first cell distance.
venkateshaero is offline   Reply With Quote
Old   January 25, 2013, 17:20
Question
Anna Tian's Avatar
Meimei Wang
Thanks. May I ask another question?
If I use laminar model(no model), do I need to have Y+ smaller or equal to 1?
Thank you.
Best regards,
Meimei
Old   January 26, 2013, 08:48
venki
please post your problem brief. whether its Heat transfer or only fluid flow problem. I will send some data based on that. that data will answer your question. .
Old   January 26, 2013, 10:42
Anna Tian's Avatar
Meimei Wang
It's a very simple case. Just laminar flow go through a rectangular pipe. But there's a 90 degree turning in the middle. There's nothing about heat transfer. Do I need to consider Y+ for laminar flow?
Just wondering: If it's for heat transfer, Y+ will need to be below 1, right?
Best regards,
Meimei
Old   January 27, 2013, 05:38
venki
Based Turbulence models Y+ limitation is there for each models(like K-omega ,K-epsilon). if u want caputure flow parameter along vertical. u have make fine mesh near wall.For Y+ consideration i will refer and answer your question later .
Old   June 7, 2013, 18:04
immortality's Avatar
Ehsan
immortality is on a distinguished road
Hi
I have a question like Anna.
Anna did you find an answer to your question about importance of y+ in laminar cases?
and is it important that flow be compressible or incompressible?
thanks.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   June 8, 2013, 09:04
Lefteris
Aeronautics El. K. is on a distinguished road
Originally Posted by Anna Tian View Post
There are formulas for the estimation of the boundary layer thickness whether that is laminar or turbulent. Use them.
Lefteris
Aeronautics El. K. is offline   Reply With Quote
Old   June 13, 2013, 05:10
Smile
  #12
Anna Tian's Avatar
Meimei Wang
Originally Posted by immortality View Post
Hi
thanks.
I think usually the boundary layer thickness doesn't strongly depend on whether the flow is compressible or incompressible. Y+ can be defined for laminar flow but doesn't make too much sense. We can use Blasius theory to estimate the laminar boundary thickness then put 11 points to the boundary layer. This could be a good starting point. Checking and grid independence study need to be done afterwards.
Best regards,
Meimei
Thread Tools
Trackbacks are On
Number of cells in mesh don't match with size of cellLevel colinB OpenFOAM Native Meshers: snappyHexMesh and Others 11 January 13, 2015 12:47
Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Mesh Utilities 41 January 17, 2013 03:43
Boundary Layer roughness/ low reynolds wall treatment Luigi_ STAR-CCM+ 1 March 14, 2012 09:40
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 06:18
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 20:23
