January 23, 2013, 01:07 |
asking about the dynamic pressure
Rong Yue
Rep Power: 13 |
Hi everyone. I simulated the pressure and velocity in an airflow 3-d area. I calculated the dynamic pressure at three outlets based on the equation :Pd=0.5*rho*v2. But the calculated results are different with the simulated results (dynamic pressure at the three outlets). I am not sure if my velocty simulated is wrong. I am appreciated with all your help! Many thanks!
January 23, 2013, 13:56 |
Rong Yue
Rep Power: 13 |
Does anybody know? Thank you so so much!
January 23, 2013, 23:03 |
Chris DeGroot
Rep Power: 17 |
Your question is way too general to answer.
January 24, 2013, 02:05 |
Rong Yue
Rep Power: 13 |
January 24, 2013, 08:27 |
Chris DeGroot
Rep Power: 17 |
You haven't described what you are simulating or how you have set it up. Without more information it isn't possible to answer your question.
January 24, 2013, 12:43 |
Rong Yue
Rep Power: 13 |
I simulated the airflow in a 3 dimensional space, there is one inlet at the bottom and three outlets at the side . I take velocity-inlet and outflow as the boundary conditions. There is reversed flow but it is still converged. I calculated the dynamic pressure at the outlets based on the eqution and compared the results with the simulated results from the report. It is not equal. I am so confused about that. Does anybody has the same problem?
January 24, 2013, 12:50 |
Chris DeGroot
Rep Power: 17 |
You haven't mentioned what software you are using. Is it Fluent? The backflow could be a problem. If it is turbulent, what are your backflow conditions? Do you expect that there would be backflow in the physical situation? How do you know it is converged? Did you check monitor points or just the residual? Since you are interested in dynamic pressures this would be an appropriate monitor. Have you checked grid independence?
January 24, 2013, 13:15 |
#8 | |
Rong Yue
Rep Power: 13 |
January 24, 2013, 14:00 |
#9 |
Chris DeGroot
Rep Power: 17 |
The residual is not enough to declare convergence, especially if you are using the default convergence criteria in Fluent. Try dropping the convergence criteria by and order of magnitude and see if the solution changes. Keep dropping it if the solution changes.
Grid independence means to run the calculation on successively finer grids (recommend doubling total number of volumes each time) to make sure you are running a fine enough grid. If the backflow persists you might need to modify your outlets. How you would do this depends on the physical situation you are modelling. |
January 24, 2013, 14:35 |
#10 |
Rong Yue
Rep Power: 13 |
So you mean the reversed flow is not allowed to exist even if it is converged?
January 24, 2013, 14:46 |
#11 |
Chris DeGroot
Rep Power: 17 |
It is possible to have reversed flow in a converged solution, but more often than not it is a sign of trouble. Plus if your backflow conditions are not reasonable there will be an impact on your solution. It could be that your outlet is not properly modelled. You'll have to think about the physics of the actual problem to figure this out. I think you probably actually want a pressure outlet not an outflow boundary since the outflow boundary condition assumes the flow is fully developed. Read the section of the User Guide "Using Outflow Boundaries". I think you will find it is not appropriate for your situation.
January 24, 2013, 15:42 |
#12 |
Rong Yue
Rep Power: 13 |
Because I don't know the pressure at the outlets and need to simulate using fluent, so i have to choose outflow as the boundary condition. It's impressible flow. Thank you so much for your explanation. I appreciate your help!
January 24, 2013, 15:50 |
#13 |
Chris DeGroot
Rep Power: 17 |
Fair enough. Just make sure your outlets are located such that the outflow boundary condition is well-posed as describe in the User Guide. Maybe you need to simulate some of the space surrounding the box as well.
Display Modes | |
Pressure Inlet VS velocity Inlet difference | Mohsin | FLUENT | 9 | January 4, 2021 11:34 |
"Pressure Inlet" Boundary Setup | Wijaya | FLUENT | 15 | May 18, 2016 11:08 |
Pressure BC for combustion chamber | Giuki | FLUENT | 1 | July 19, 2011 12:35 |
Question about the dynamic pressure in the lifting/drag coefficients | tenkio | Main CFD Forum | 1 | May 17, 2011 12:23 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 03:15 |
