Non-linear analysis of Floating circular cylinders
Old   April 19, 2006, 03:19
Default Non-linear analysis of Floating circular cylinders
Dr.K.Thiruvenkatasamy
Dear members,
I would like to analyse Non-linear motion of Floating circular cylinders of large amplitudes. The cylinder may be of 30m high with 10m dia with 8m wave excursions inside the cylinder. It is like a Oscillating Water Column(OWC. Any details on software for non-linear analysis,
non-linear models welcome
thanks in advance
Old   April 19, 2006, 10:11
Default Re: Non-linear analysis of Floating circular cylin
diaw
Dr. K, I wonder if it would be worth your while also trying to contact a Marine Engineering forum - if such an entity exists.
I wish you well in your search - don't pass up the book reference I gave you previously. This could provide you some useful additional links.
diaw...
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
solution diverges when linear upwind interpolation scheme is used subash OpenFOAM 0 May 29, 2010 01:23
non-linear analysis of floating bodies Dr.K.Thiruvenkatasamy Siemens 0 April 19, 2006 03:40
non-linear motion of Floating Circular Cylinders Dr.K.Thiruvenkatasamy Main CFD Forum 2 April 14, 2006 00:29
non-linear motion of Floating Circular Cylinders Dr.K.Thiruvenkatasamy Main CFD Forum 1 April 10, 2006 11:28
