April 18, 2006, 10:36 |
queries on M.Peric's example code
in the codes of Computational methods for fluid dynamics, density sets as 1, and viscosity is equal to 0.001. So what kind of material does it delegate? water (density=1000, viscosity=0.001), or Air (density=1.29, viscosity=0.000001). the corresponding code can be downloaded from springe's ftp
ftp://ftp.springer.de/pub/technik/peric/ |
April 18, 2006, 13:08 |
Re: queries on M.Peric's example code
The beauty of CFD, comparing to the experiment, is that you can specify any property values such as density and viscosity to the fluid. Let's say for a flow in pipe, Reynolds number determines the flow being laminar or turbulent. Re=(density*velocity*diameter/Viscosity). By adjusting density and/or viscosity, you can achieve desirable Re without changing velocity.
April 18, 2006, 20:28 |
It solves the non-dimensional Navier-Stokes equations of Reynolds number=1000 for any fluids. If you read the Patankar's book, there is a section explaining this kind of treatment.
Display Modes | |
The FOAM Documentation Project - SHUT-DOWN | holger_marschall | OpenFOAM | 242 | March 7, 2013 13:30 |
Debugging Unsteady 2-D Panel Method Code: Wake Modeling | RajeshAero | Main CFD Forum | 5 | November 10, 2011 06:48 |
How to make code run in parallel? | cwang5 | OpenFOAM Programming & Development | 1 | May 30, 2011 05:47 |
Open Source Vs Commercial Software | MechE | OpenFOAM | 28 | May 16, 2011 12:02 |
Small 3-D code | Zdravko Stojanovic | Main CFD Forum | 2 | July 19, 2010 11:11 |
