Increasing instability for flow around as cylinder. |
February 12, 2013, 04:35 |
#21 |
Filippo Maria Denaro
Rep Power: 71 |
In my opinion, the grid is extended enough from the cylinder, perhaps I don't understand the requirement to use an O-grid ...
First, the instability should appear also for laminar flows, therefore I would try the solver without any tubrulence modelling, then I see only 600 time-steps that can be not sufficient to develop instability. An acceleration of the onset of the instability can be obtained by prescribing small fluctuations in the initial condition. Finally, owing to the particular shape of the grid, I would take attention to the outflow conditions |
February 12, 2013, 05:34 |
#22 | |
Arjun
Rep Power: 34 |
can't really say. Because with iNavier and old versions of fluent like fluent 6.3 i could get vortex shedding even when boundaries were close. I was just sharing my experience with such problem how it went away. So it is worth trying. Personally I do think with finite volume codes like fluent starccm he should have got this vortex shedding without much of hassle. |
February 12, 2013, 05:35 |
#23 | |
Arjun
Rep Power: 34 |
that may very well be the issue here. It usually requires much larger number of steps to get. |
flow over a cylinder urgent! | kevin | FLUENT | 8 | August 11, 2015 13:00 |
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 11:47 |
Incorrect Drag and Drag Coefficient for flow over a cylinder | ozzythewise | Main CFD Forum | 8 | June 13, 2012 06:24 |
[blockMesh] Specifying boundary faces failes in blockMesh | blaise | OpenFOAM Meshing & Mesh Conversion | 0 | May 10, 2010 03:56 |
rotating cylinder using sliding mesh | Tim Daly | FLUENT | 1 | November 9, 2008 23:02 |
