Gauss-Seidel vs. SOR
Old   April 15, 2006, 12:26
Default Gauss-Seidel vs. SOR
pXYZ
I have written a little program which solves an equation system (3x3) with a Jacobi- or Gauss-Seidel-procedure.
There is no doubt that the Jacobi-solver needs much more iterations to solve the problem than Gauss-Seidel.
I wonder that a successive over relaxation with Gauss-Seidel (SOR) does not lead to a further reduction of iterations. What could be the reason?
Thanks for help.
Old   April 16, 2006, 09:15
Default Re: Gauss-Seidel vs. SOR
johannes
As you said you tried it with 3x3 matrices. Try it with some 100x100 matrices and see what happens. There can be many causes for the problem you described.
Old   April 16, 2006, 10:54
rt
Dear
Probably you don't use optimum over-relaxation parameter, this parameter usually is found with numerical experiment but 1.7 is usually good choice.
good luck
Old   April 17, 2006, 17:01
pXYZ
omega=1.7 ???
I thought it should be around between 0 and 1. I tested it but it does not improve my convergency.
I cannot see any reason why 10x10 should lead to a different behaviour than 3x3. Could you try to give me an explanation?
Thanks.
Old   April 17, 2006, 21:40
Darren
Having omega between 0 and 1 is under-relaxation, so omega should definately be >1 (and as said 1.7 usually does ok).
What is your matrix?? Iterative methods generally get used for sparse, diagonally dominant problems (like discrete PDE operators).
Also as said, the difference between SOR and GS is going to become more noticable as the size of the matrix increases (like 100's by 100's).
The convergence of iterative methods has alot to do with the spectral properties of the matrix (eigenvalues)
Old   April 19, 2006, 11:01
sam
when omega = 1 . it is simply as GS. value greater than 1 means overrelaxation and less mean uder relaxation.
Old   April 19, 2006, 13:47
rt
For better understanding the effect of omega (0<omega<2 is convergent) on system behavior, i suggest you to vary omega with small step size, between 0 and 2, and investigate variation of number of iterations with variation of omega, so select optimom value.
Also the number of iterations is completely function of system behavior e.g., when we deal with ill-posed systems (have large condition number) usually we don't acheive performance when we switch from GS to SOR. For such systems preconditionnig and application of non-stationary iterative methods (e.g. CG, BICGSTAB or GMRES) is good cure.
Problem in fvschemes divSchemes cannot use Gauss linearUpwind nico765 OpenFOAM Bugs 30 August 9, 2018 07:39
please help me which solver is better for my application Ger_US OpenFOAM 8 January 8, 2013 12:29
Submarine with SimpleFoam alex_rubel OpenFOAM 20 February 25, 2011 06:34
solution diverges when linear upwind interpolation scheme is used subash OpenFOAM 0 May 29, 2010 01:23
Stability problems with kepsilon in external aero edreed OpenFOAM Running, Solving & CFD 21 July 16, 2008 15:00
