Pulsatile flow for global mass conservation
Old   February 8, 2013, 22:33
Default Pulsatile flow for global mass conservation
Woojin Kim
woojin is on a distinguished road
I have a question for pulsatile flow.
In pulsatile flow, negative inflow is generated during some period.
To conserve global mass conservation, mass flux should be also negative in the outlet side.
And I use convective boundary condition in the outlet side.
dui/dt + cdui/dx = 0
After applying to convective boundary condition, following equation is used.
ui=ui*Qin/Qout
At this procedure, some problems occurs.
If Qin is zero, ui becomes zero.
I think this flow is non-physical.
Do you have any ideas to fix this problem?
woojin is offline   Reply With Quote
mass conservation, pulsatile flow
Mass flow rate: calculation v/s computation beguxa FLUENT 5 December 2, 2018 21:02
Species mass flow inlet lorenz FLUENT 3 March 15, 2012 07:26
Mass flow rate sepidecent CFX 0 August 9, 2011 00:15
Mass flow and U-Mom flow in CFX Zhihua Xie CFX 0 September 3, 2007 09:49
mass flow in is not equal to mass flow out skarp CFX 8 August 19, 2007 01:55
