[Sponsors] | |||||
Ranald M Engelbeck
Rep Power: 2 ![]() |
I have successfully compiled Program 14 from Katz & Plotkin's book "Low Speed Aerodynamics" Now I am trying to debug the code to ensure it works.
The baseline case set up in the published code yeilds a reasonable result: Inputs: ALPHA1=5.0 CROOT= 1.0 CTIP=1.0 XTIP=0.0 ZTIP=0.0 B=10.0 VT=1.0 JB=3 The answer was not published....hopefully, this matches someones answer? CL= 0.4487 L= 2.2433 CM= 0.1148 CD= 0.0248 ![]() Looking into the code brought up few issues I wanted to ask about: 1.) The programs variable VT I am interpreting as free stream velocity and RO to be density by their use in the program. However, setting the values of both of these variables in the program to 1.0 makes me wonder if they are normalized? ![]() 2.) However, when I tried to run a geometry more representative of an real airplane (dimensions in inches) I get nonsensical anwsers: Inputs: ALPHA1=5.0 CROOT= 246.59 CTIP=58.18 XTIP=311.24 ZTIP=-59.69 B=670.25 VT=1.0 JB=3 Outputs: CL=-.7883E+08 L=-.4026E+13 CM=-.3876E+10 CD=-.3926E+07 ![]() Am I missing some other geometry normalization...say wing dimensions normalized to root chord (CROOT)? 3.) There is a fragment of code correcting the individual panel sweeps from chord wise/spanwise to streamwise/perpendicular to streamwise in the code leading up to the force and moment calculations.... C FIRST ORDER CORRECTION FOR PANEL SWEEP QL=QL+QM*(DX**2+DZ**2)/DR QM=QM*(DY**2+DZ**2)/DR Is there a discussion of they theory behind this correction somewhere? Anybody have any experiance with this code? How about a website that has the source code in machine readable format?...maybe I have a typo somewhere? Ron |
Ranald M Engelbeck
Thank you to Dr Katz for allowing me to upload source code....
#3 | |
Lefteris
Rep Power: 3 ![]() |
a) use SI units. not inches. b) fortran uses rads and not degrees so you should be sure that you use rads or that the conversion from degrees to rads is done properly PS ok I just noticed that the conversion from degrees to rads is done : ALPHA1*PAY/180.0 so you don't neet to worry about that. Try to use SI units for the rest.
Lefteris Department of Mechanical and Aerospace Engineering |
Ranald M Engelbeck
I do not think the units of the length dimensions affects the dimensionless results of lift drag and pitching moment coefficients since the should be referenced to wing area and chord length. One way of looking at the conversion factor between si and imperial units is as a geometry scaling factor....this is why I think the input length dimensions and speed are normalized by dividing by some reference length. Katz has no description on how to interpret the inputs, and I can't figure out if I have some coding error or the inputs are normalized by some length parameter like root chord...not a clue!
Lefteris
I was working on CAFFA code (by prof. Peric) and although nowhere was clearly stated, the code was working properly only in SI units thus, I suggest you try SI units (ultimately this is the meaning of the SI units, a common system so that people around the world don't get confused).
Checking your grid's scaling is of critical importance as well. Whatever units you have used, use the appropriate factor to convert it to m.
Ranald M Engelbeck
Remember the section of code I refered to in the orgional post? ie:
C FIRST ORDER CORRECTION FOR PANEL SWEEP QL=QL+QM*(DX**2+DZ**2)/DR QM=QM*(DY**2+DZ**2)/DR ...well, I commented it out and all the coefficients came back to magnitudes I was expecting....so I conclude that this code fragment is at least one of the problems...Soooo...what is this section of code doing? Simple sweep correction? |
| Tags |
| debug katz program 14 |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| ANSYS program has stopped working? | chihoangkt | ANSYS | 0 | July 16, 2012 16:41 |
| error in program: | mani.rajendiran | Fluent UDF and Scheme Programming | 0 | March 22, 2012 12:25 |
| Chemkin Forums? PSR.f program help? | johnjohnmulley | Main CFD Forum | 1 | October 6, 2011 06:38 |
| Which opensource and free CAD program? | Xwang | Main CFD Forum | 1 | October 24, 2010 17:29 |
| Update boundary conditions calculated by an external program | CedricVH | OpenFOAM | 2 | January 15, 2010 11:55 |
