Surface Radiation - parallel computing
Old   April 27, 2006, 09:56
Default Surface Radiation - parallel computing
Sile
Hi, I am looking for some help regarding non-convex radiation computing. I have heard that there are some issues running these models on parallel processors but I can't find any information on it! I'm very new to the field so any help at all would be much appreciated. Many thanks, Sile
Old   April 30, 2006, 03:08
Default Re: Surface Radiation - parallel computing
Rami
Sile,
It very much depends on your solution method.
For ray-trace (Monte-Carlo or DTM) parallelization is trivial, since each ray is independent of other rays. Consequently we reached nearly 100% parallel efficiency with 16 CPUs (Cray and SGI Origin).
With DOM, FVM etc., the parallel efficiency depends a lot on your base method and the parallelization method. Please see our paper (and references therein)
J. Tal, R. Ben-Zvi, A. Kribus, A High-Efficiency Parallel Solution of the Radiative Transfer Equation, Numerical Heat Transfer, Part B, Vol. 44 No. 3, pp. 295-308, 2003.
BTW: 1. What do you mean by "non-convex radiation computing"? 2. Are you considering inter-surface radiation or radiation in participating medium?
Old   May 2, 2006, 03:48
Sile
Rami,
Thank you very much for your reply - it is much appreciated. I'll check out that reference.
I am considering inter-surface radiation. The term non-convex was used in the project description I was given. My understanding of it in the context of the project(although I may be wrong) is that it refers to inter-surface radiation on concave surfaces, i.e. non-flat or convex surfaces. Thanks again! Sile
parallel computing (MPICH2 local) error massage ggxhyst CFX 3 July 20, 2011 16:39
Parallel Computing on Multi-Core Processors Upgrading Hardware CFX 6 June 7, 2007 15:54
surface to surface radiation heat transfer? suresh Siemens 1 July 7, 2006 06:54
Radiation flux to the wall surface Jason Phoenics 1 May 26, 2004 01:13
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 12:00
