February 15, 2013, 11:58 |
SA-DES Cylinder with SA-RC?
Martin Hegedus
Rep Power: 19 |
I would like to implement a SA-DES model for a cylinder.
Does one use the SA model with Rotation/Curvature Correction (SA-RC) or without? The SA-RC seems to be the physically correct model because it produces less eddy viscosity at the center of a vortex than SA. However, the references I've found in regards to SA-DES seem to be with the uncorrected model. |
February 15, 2013, 12:38 |
Martin Hegedus
Rep Power: 19 |
I did find one reference http://www.csc.kth.se/~jhoffman/arch...nDESCC1999.pdf which seems to indicate that RC helps. Any shared thoughts or references would be much appreciated. Thanks.
Incorrect Drag and Drag Coefficient for flow over a cylinder | ozzythewise | Main CFD Forum | 8 | June 13, 2012 06:24 |
[blockMesh] Specifying boundary faces failes in blockMesh | blaise | OpenFOAM Meshing & Mesh Conversion | 0 | May 10, 2010 03:56 |
rotating cylinder using sliding mesh | Tim Daly | FLUENT | 1 | November 9, 2008 23:02 |
How to use DES well? | Daniel | Main CFD Forum | 0 | October 26, 2008 05:59 |
Turbulent steady flow around a circular cylinder | Mirek Kabacinski | FLUENT | 0 | July 23, 2003 18:40 |
