[Sponsors] | |||||
#21 | |
Lefteris
Rep Power: 3 ![]() |
(http://www.engineeringtoolbox.com/wa...ity-d_596.html) Another thing that I always ensure is to scale the grid. For example, if you have created the grid with the dimensions in mm, then before running your simulation you should convert your grid's dimensions from mm to m.
Lefteris Department of Mechanical and Aerospace Engineering |
#22 |
Osman
Rep Power: 2 ![]() |
The recirculation length L/D at Re=40 is around 2, however, from literature i found that it is in the range 2.2~2.4.
Could you please tell me what could be the reason?? (I used different grid size, however i got the same results) In addition, i am using Tecplot to calculate the drag coefficient. For example: If the Cylinder radius is for example R=0.05 & the grid size is dx=0.01 I could not get accurate results for the drag coefficient if the the calculation is taking place with the same radious. But, i get accurate results for the drag coefficient if i used a radious smaller than the actual radious such as R=0.0485. What could be the reason???? |
#23 | |
Lefteris
I would use much smaller grid spacing. dx=0.01 is too large I think compared to diameter of the cylinder.
#24 |
Osman
Thanks a lot for your reply.
what about the 2nd half of my question about tecplot!! i am using Tecplot to calculate the drag coefficient. For example: If the Cylinder radius is for example R=0.05 & the grid size is dx=0.01 I could not get accurate results for the drag coefficient if the the calculation is taking place with the same radious. But, i get accurate results for the drag coefficient if i used a radious bigger than the actual radious such as R=0.055. What could be the reason???? |
#25 |
Lefteris
I don't really get it.
Why don't you just compute in your code the force on the cylinder?
#26 |
Osman
Actually, now, i am calculating it in my code (Immersed Boundary Code).
The drag coefficient is excellently matching the reference data at Re=185 However, the lift coefficient is small around 0.302 In reference data it is around 0.42 Do you have any suggestion?? |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... | 12 | May 2, 2013 10:52 |
| Mesh conversion problem (fluent3DMeshToFoam) | Aadhavan | OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... | 1 | December 12, 2012 10:38 |
| [ICEM] Export ICEM mesh to Gambit / Fluent | romekr | ANSYS Meshing & Geometry | 1 | November 26, 2011 12:11 |
| Problem in running ICEM grid in Openfoam | Tarak | OpenFOAM | 6 | September 9, 2011 17:51 |
| Problem in IMPORT of ICEM input file in FLUENT | csvirume | FLUENT | 2 | September 9, 2009 01:08 |
