May 2, 2006, 11:51 |
Question on adding source to momentum
Does Adding source to momentum equation create an extra term in k-epsilon turbulence model?
say: Ut+div (UU) = -grad(P) + S where S is the source.. what would the extra term if any in k and e equations? Can someone direct me to notes on K-E derivation from the basic momentum equations?? Thanks, CFDtoy |
Simulation of Axial Fan Flow using A Momentum Source Subdomain | Liam | CFX | 28 | July 16, 2013 08:24 |
Adding implicit source term to momentum equation | fs82 | OpenFOAM | 6 | September 23, 2009 03:29 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
Momentum source | Jackie | CFX | 0 | February 16, 2003 01:16 |
