About inlet peturbation generation method?
Old   May 4, 2006, 04:09
Default About inlet peturbation generation method?
leaf
Is there any literature about inlet perturbation generation method?I intend to add some random perturbation to the shear layer of a jet and investigate how these perturbations evolves in space and time. Any book or paper will do.
Old   May 4, 2006, 04:11
Default Re: About inlet peturbation generation method? *NM*
leaf
Old   May 4, 2006, 06:22
diaw
A thought... Why not add 'well defined' perturbation signals to your flow in preference to 'random' - eg. square-wave pulse, triangular spike, & so on. Look at consistently varying certain key parameters eg. pulse amplitude, pulse duration, pulses per second. Then repeat the exercise with increasing jet velocity. You are bound to end up with some extremely interesting results.
Turn off the convection-stabilisation.
Enjoy...
diaw...
Old   May 4, 2006, 09:05
Tian_FB
Well,I think you may do some worke on the theory of stability of the flow if could.Or, you may leran about stability of flow from some text and I think you may have some ideals.
Old   May 4, 2006, 09:21
Guillaume
Check towards turbulent DNS/LES papers. It is sometimes used flow perturbations. Otherwise, they initialise with prescribed turbulent fields but it is not of interest for you.
Old   May 4, 2006, 14:57
agg
Try this one - i use it and it works nicely
"A digital filter based generation of inflow data for spatially developing direct numerical or large eddy simulations" - M. Klein, A. Sadiki, J. Janicka
Journal of Computational Physics 186 (2003) 652â€"665
I have a pdf version of the paper, if you don't have access to it.
simpleFoam Blows up with Parabolic Inlet Pipe Flow swahono OpenFOAM 0 December 6, 2010 19:37
Pulsating flow with non-reflective inlet boundary cc1000 CFX 6 April 27, 2009 08:10
Bug in inlet generation henry OpenFOAM Bugs 4 February 24, 2009 06:06
Diffusion component at inlet Balaji FLUENT 2 August 8, 2005 07:37
Latest news in mesh generation Robert Schneiders Main CFD Forum 0 March 2, 1999 04:07
