February 25, 2013, 09:27 |
A tube heat transfer simulation
Jing Shi
Rep Power: 13 |
Hi, I want to simulate a pipe in the air, with heated fluid flowing into the pipe, and try to get the temperature of the outlet flow.
My first model is just a pipe, with boundary conditions: velocity inlet and temperature, pressure outlet and temperature, coupled interface between the fluid and the tube inner wall, and tube outside wall with convection boundary(as I just focus on the change along the pipe not the area around it, I don't include the area around the pipe in the model, thinking of the convection boundary could transfer the heat out). the geometry and mesh is shown in Fig.1 The second try add the area around the pipe, with boundary conditions: velocity inlet and temperature, pressure outlet and temperature, coupled interface between the fluid and the tube inner wall, coupled interface between the outer tube wall and the area around the pipe (air), and wall with constant temperature boundary (assuming the temperature at some distance away from the tube is free constant air temperature). The geometry and mesh is shown in Fig.2 The results of the two models are different, I have no idea which is right, or both wrong? Is there any mistake in my understanding of this problem model? Regards, Jing Last edited by Jing; February 26, 2013 at 04:21. |
boundary conditions, heat transfer, tube flow |
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff | swahono | OpenFOAM Running, Solving & CFD | 10 | October 15, 2018 05:43 |
Quenching simulation : how to set up a conjugate heat transfer between solid&liquid | Rockda | FLUENT | 24 | August 30, 2016 06:33 |
heat transfer inside a tube | khaitanajay | FLUENT | 3 | October 13, 2012 21:57 |
Simulation of cavitation flow:problem of heat transfer | kiwishall | CFX | 4 | October 5, 2012 08:44 |
Natural convection - Inlet boundary condition | max91 | CFX | 1 | July 29, 2008 20:28 |
