May 8, 2006, 15:11 |
Y+ in FLUENT
My question is actually about FLUENT. Does anyone know how to check, define, or control Y+ in FLUENT ?
Appreciate it. ~Andrew ----- PS. sorry about confussion. |
May 8, 2006, 22:15 |
Re: Y+ in FLUENT
Dear Andrew, Well,Y+=yv*/ν,v*=(τw/&rho^0.5,τw is the shearing force on boundary,ν is the kinematical viscosity,ρ is the density of fluid.In fluent,y is the first layer grid around boundary,i.e. if the hight of the grid around the boundary is L, the Y+=Lv*/ν.So ,I think you can change the size of grid around boundary ,or equilibrium grid (a commond in fluent). I think if you had read some books about the turbulence boundary layer,you may now the exactly means of y+ and why and how we control the magnitude of it.
Cheers, Tian |
May 15, 2006, 05:39 |
Re: Y+ in FLUENT
please use the FLUENT forum for fluent questions!!
Check y+: use: xy plot -> turbulence -> yplus, the surface is the wall of your geometry control y+: adapt-> yplus Hope, it helps. Ralf |
September 17, 2019, 03:30 |
y+ VS. y* ---> explained!!
Here's my take on wall treatment, including a paragraph on y* (I called it: "Why Star?..." 😂:
https://cfdisraelblog.wordpress.com/...-ansys-fluent/ |
Stopping a Fluent batch job AND saving the data! Possible? | Volker Pawlik | FLUENT | 13 | December 28, 2020 04:16 |
A Problem of Fluent Interpreted UDF: parse error | knight | Fluent UDF and Scheme Programming | 25 | August 16, 2018 10:26 |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
Compared MRFSimpleFoam and Fluent in a centrifugal pump! | renyun0511 | OpenFOAM Running, Solving & CFD | 8 | July 6, 2010 06:24 |
Problems in lauching FLUENT | Lourival | FLUENT | 3 | January 16, 2008 16:48 |
