Please Help...Effect of wind tunnel size on coefficient of drag & drag force.. |
March 3, 2013, 07:08 |
adi
I am getting different value of Drag Force Fd & Coefficient of Drag for a verticle plate of 1 m^2 cross sectional area and 100 mm thickness while changing the wind tunnel size in project Falcon by autodesk (I attached photo of analysis with different wind tunnel size..take a look). plz help me to decide optimal size of virtual wind tunnel in falcon so that i can get correct answer..
2. Wht is the volume stand for that i highlighted in the pics?? plz reply.. Thanks & Regards.. |
March 3, 2013, 08:34 |
#2 | |
andy
March 5, 2013, 09:24 |
venki
You have to desired based on characteristics length of model
March 5, 2013, 11:52 |
#4 | |
Lefteris
Maybe someone who is more familiar with the specific application can give you more insight into it.
Lefteris |
March 9, 2013, 01:57 |
Waleed
Dear friend I checked a research done on this issue before but the researcher was using ansys fluent and please note that there is no standard dimensions for wind tunnel and conclusion is take from the right, left, top and up stream a distance equale 5 times your model width and take after the model in the down stream about 10 to 12 times the model width too,
hope you are getting a good results with this dimensions, and there is anothe way to check your results because your model shape is regular so you can check the avarage drag and left coeff. from any code like BS, thank you Waleed |
March 12, 2013, 13:38 |
If you specifically study the force and the drag, so you must create a very large wind tunnel for your purpose. It's supposed to have a wind tunnel with the typical length scale of 30 times at the typical length scale of the model.
I have one individual idea like that. Try to resize your wind tunnel until the result is independent or weakly dependent on the wind tunnel size, say, if the results are about 5% different in some norms. Then you will get the ideal size of your wind tunnel for the test case. |
falcon wind tunnel, optimum wind tunnel, wind tunnel size |
ActuatorDiskExplicitForce in OF2.1. Help | be_inspired | OpenFOAM Programming & Development | 10 | September 14, 2018 11:12 |
Too low drag coefficient on a bus | Roland R | CFX | 8 | September 21, 2012 05:23 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
Simulating a Göttingen type wind tunnel in FLUENT | Chris | FLUENT | 3 | December 4, 2006 17:33 |
