2-way FSI, System Coupling error
Hello, everybody!
I am trying to perform a 2-way FSI considering a gas compressor blade. So, I linked Transient structural with Fluid flow (Fluent), and connected the setup cells of those with System Coupling. When I update the Solution cell of the System Coupling I get the following message: System coupling run completed with errors: the MAPDL beginning time 1 is different from the System Coupling service beginning time 0. Does anyone can tell what should I do to settle it? |
you need to reset the solution cell in the structural analysis (go to the solution--> RMB -->reset data)
| All times are GMT -4. The time now is 13:12. |
