Gas/Liquid with VOF
Old   May 11, 2006, 04:34
Default Gas/Liquid with VOF
rt
In the multiphase option of fluent with VOF method it is possible to define primary phase (e.g. gas) as ideal gas and secondary phase (tracked phase e.g. liquid) as incompressible,
What is the fluent's model for this? what is method of cupling between this two model (incompressible and probably compressible) it is especially confusing for interfaces cell. If anyone have information about this or knowe the refrence of it, please give me guide.
with Regard.
Old   May 11, 2006, 10:09
Default Re: Gas/Liquid with VOF
Renato.
Hi RT,
why are you willing to consider the gas phase as an ideal gas?
I'm not a Fluent user, so I don't know regarding the Fluent's VOF formulation, but I could say that when working with interface between gases and liquids it's common to treat gas+liquid as it was only one incompressible fluid with properties varying. It's perfect understandable since most of the inertia is due the liquid phase. In this sense you can solve your liquid phase and forget about the gas phase. Furthermore, some modern solvers don't solve the gas phase. In this case the solver runs faster since it does not lose time solving the fluid flow in some region where we're not interested.
Regards
Renato.
Old   May 11, 2006, 10:41
rt
Your discussion is correct and is well-known, but i am confused that how fluent treat incompressible and ideal gas simulteneously!, there is not any material about this in fluent help.
But about why ideal gas assumption !!! as i model mold filling problem, incompressible assumption of gas needs design of some outflow for gas exhasing that is not simple task for complex geometry also this increase ill-poseness of system and increase computational cost.
Old   May 11, 2006, 11:42
Renato.
I see what you mean...
Couldn't you consider that the gas phase can exit the mold without constraints? By this way you could neglect the compressibility effects... Is your mold completely closed?
I'm sorry because I can't help you with Fluent, but I would suggest a nice paper related to mold filling that I read recently:
Hetu, JF and Ilinca Florin, "A Finite Element Method for Casting Simulations", Numerical Heat Transfer, Part A, 36:657-679, 1999
in this paper some assumptions regarding your problems are discussed.
Old   May 11, 2006, 11:58
rt
The effect of gas don't have importance for me because my mold is porous (silica sand mold) and gas easily goes out from it.
Also please send to me the mentioned paper:rohtav@yahoo.com
UDF Defining VOF Free Surface at Outlet Alex Fluent UDF and Scheme Programming 13 August 8, 2012 16:50
Question:Considerations about the evaporation in VOF dokeun FLUENT 10 February 24, 2011 20:47
plz rply urgent regrding vof model for my system garima chaudhary FLUENT 1 July 20, 2007 08:37
urgent query regarding vof model plz rply Garima Chaudhary FLUENT 0 July 13, 2007 02:20
Difficult BCs about Freesurface Simulation by VOF Yongguang Cheng FLUENT 0 September 19, 2003 07:39
