May 18, 2006, 22:10 |
two-phase flow with variable surface tension
hi there... i am looking for commercial software that c an perform two-phase flow with variable surface tension (marangoni effect). any suggestion is greatly appreaciated. thank you very much. yf
May 19, 2006, 09:58 |
Re: two-phase flow with variable surface tension
Check out www.openfoam.org. You get source code, so that you might be able to do it yourself. Currently, it has timeVaryingConactAngle, that is, wall contact as a function of time. It should be quite straight forward to make the surface tension as a function of time (or location). But, I have not tried this myself. To make sure of this, contact www.opencfd.co.uk. Pei |
Display Modes | |
VOF & Variable Surface Tension in FLUENT | SeamusTCD | FLUENT | 13 | June 18, 2022 01:51 |
Thermocapillary free surface flow | zakifoam | OpenFOAM Running, Solving & CFD | 10 | December 12, 2016 11:44 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
Looking for software for free surface flow | Eric Jiang | Main CFD Forum | 12 | December 17, 2007 23:39 |
