meshing in flow separation region
Old   March 10, 2013, 22:10
Default meshing in flow separation region
Joseph Neil
ajneil is on a distinguished road
can anyone help me in my turbulent flow problem with sudden expansion pipe. i am using k-e model with standard wall function in fluent. i ve meshed the geometry in gambit and i didnt get t y+ values along the wall above 12.
regards
jose
ajneil is offline   Reply With Quote
Old   March 11, 2013, 16:14
Lefteris
Aeronautics El. K. is on a distinguished road
Maybe you could use the Enhanced Wall Treatment.
regards
jose
Lefteris
Aeronautics El. K. is offline   Reply With Quote
Old   March 14, 2013, 11:58
Joseph Neil
1) can u explain how enhanced wall treatment gives better results?
2) is it very herd to mesh in the flow separation region?
Old   March 14, 2013, 13:19
Lefteris
Using standard wall functions means that you ignore the viscous sublayer and that's why you need a y+ >30 (you may want to take a look here: http://www.cfd-online.com/Wiki/Law_of_the_wall).
If y+ is lower than that, Fluent offers the choice to use the enhanced wall treatment whose details you can read here: http://cdlab2.fluid.tuwien.ac.at/LEH...ug/node514.htm
To mesh the flow separation region you need to have some indication as to where this region is. This can be deduced from experimental data or from a simulation on a coarse grid which you refine at the separation region.
Lefteris
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 09:48
[snappyHexMesh] Multi region meshing & recovering the original patch names fluidpath OpenFOAM Meshing & Mesh Conversion 4 May 19, 2013 19:13
Difficulty meshing a two region problem james15 STAR-CCM+ 5 August 19, 2010 01:10
separation region in corner flows submitted to curvature effects Stephane Main CFD Forum 2 July 13, 1998 19:06
Wall functions or low-Re models? J. P. Main CFD Forum 7 July 9, 1998 11:11
