March 12, 2013, 10:00 |
models for entire atmosphere
Peetak Mitra
Rep Power: 13 |
I am involved in a project which entails simulation of an air vortex ring through the atmosphere. Till now I have been using a code referenced to us by the University of Michigan known as the GITM (Global Ionosphere Thermosphere Model), which is primarily an upper atmospheric model. We tried to extend the code to the lower atmosphere but we are finding it extremely difficult and time consuming to do. Hence I wanted to know if there are any full atmosphere codes available which can simulate most of the important/relevant conditions and give comparable results, The thing is, an abstract we submitted for an AIAA conference in San Diego, US got accepted. And the papers are due by June 4th. I was hoping to have some simulations run before the same so that I can present some of my work in the conference. Hence I am looking forward to any of your suggestions on the availability of a full atmosphere code that can be referenced. Any suggestion would be very helpful. Thank you, Peetak Mitra Senior Yr. UG student, BIT Mesra, India. |
March 13, 2013, 05:33 |
Rep Power: 13 |
NWP models are complex, difficult to use and the results are not obvious to interpret. You are clearly not familiar with the atmospheric sciences, so it would be very surprising if you get anything serious in time for your conference.
You will have more chance of success if you contact your national meteorological service to seek their advice. |
aiaa, atmospheric model, codes, gitm |
Display Modes | |
Simulation of air vortex through atmosphere | alchemicscience | Main CFD Forum | 1 | March 11, 2013 08:00 |
Bad Cd results applying k-ε models to hydrofoil | spk | FLUENT | 1 | December 10, 2011 08:27 |
Incompressible Turbulence models | achinta | OpenFOAM | 4 | May 27, 2010 10:35 |
Two-fluid models vs mixture models for bubbly flows | Hansong Tang | Main CFD Forum | 6 | December 8, 2009 03:21 |
CFD models | Xie | Main CFD Forum | 0 | April 18, 2002 13:48 |
