Grid stretching ratio for different flow regions |
May 5, 2006, 05:48 |
I am still quite new to grid generation. I have been reading a few posts on this forum which states that if the grid stretching ratio is bigger than around 1.2, there 'll be errors.
However, must this practise be followed even for region such as far upstream/downstream ie places where the velocity/pressure is more or less constant? Can the ratio be higher e.g. 1.5 or even 2.0? By the way, I am using my own 2D FVM fractional step structured solver. |
May 5, 2006, 08:37 |
Re: Grid stretching ratio for different flow regio
1.2 is a rule of thumb, and not a hard and fast rule. Ideally, in regions of strong gradients even 1.2 might be a little high, while in regions of small gradients 1.5 may be perfectly acceptable. Of course, what you'll find is that even sticking to 1.2 will give very large cells after you get any distance away from the body.
May 10, 2006, 15:12 |
I'm using too my own 2D FVM to study incompressible flow about airfoil. I've used SIMPLER algorithm and second order upwind scheem for convective terms. although i've used verry small relaxation parameters (2*10**-2) my code program converge to 10**-4 and diverge again. I don't know if the problem is in the formulation of boundary conditions in numerical domain. If y're agree i'm ready to send more details and discuss further ideas.
May 22, 2006, 04:38 |
WANT HELP OF GRID STRETCHING
I just touch grid generation, and I hope to know the function of logarithm grid. Could you please give me some help? LXT
Grid independent problem for lid-driven flow | dpc-buaa | Main CFD Forum | 0 | February 22, 2011 22:24 |
flow with high turbulent viscosity ratio | Phillips | Main CFD Forum | 2 | August 25, 2008 18:01 |
computation about flow around a yawed cone | Tylor Xie | Main CFD Forum | 0 | June 9, 1999 07:33 |
ratio grid resolution (near wall/center) of dispersed bubbly flow columns using LES | Ridwan Setiadi Arrizar | Main CFD Forum | 1 | January 30, 1999 17:43 |
Incompressible flow solver (staggered grid) | J. Ehrhard | Main CFD Forum | 1 | October 8, 1998 19:47 |
