reading from line no x in fortran
Old   May 19, 2006, 02:31
Default reading from line no x in fortran
zonexo
hi,
may i know if it is possible to start reading in an ascii file from line no. x e.g line 4 in fortran?
hope someone can help. tks!
Old   May 19, 2006, 08:51
Default Re: reading from line no x in fortran
ag
You'll need to code up something to skip the first n-1 lines with dummy reads to read the nth line in. Something like
char*1 skip
do i = 1, n-1
read (iunit,*) skip end do
read (iunit,*) data you want
Old   May 19, 2006, 11:42
Default tks, what abt reading data on the same line?
zonexo
thanks ag,
that's just what i've been doing. ;-)
btw, i've data which are situated on the same line, separated by space.
i tried to read by:
do i=1,n read (1,fmt=*) u(i) end do
however using the above, i can only read in the 1st data of that line. moreover, different rows 've different no. of data. hence, it is not possible to use
read (1,fmt=*) u(i),v(i)...
and lastly, how abt if the data are arranged in this fashion:
1.12345678e1231.12345678e12312....
ie there are no space bet 2 nos although i know their length is fixed ie 1.12345678e123
thanks in advance!
Old   May 19, 2006, 13:20
Default Re: tks, what abt reading data on the same line?
pc
You can try guessing the # of variables and back up if an error is encountered. For example:
nvars=10 readin=.false. do while(.not.readin) read(iunit,*,err=5)(u(i),i=1,nvars) readin=.true. cycle 5 nvars=nvars-1 backspace(iunit) enddo
This may not be the most elegant code but it should get the job done.
In response to your second question, if you know the field width you can use a formatted read. For example,
read(iunit,5)(u(i),i=1,10) 5 format(10(1pe14.8))
Old   May 19, 2006, 13:23
pc
Sorry about the formatting, let's try that again:
nvars=10
readin=.false.
readin=.true.
cycle
5 nvars=nvars-1
backspace(iunit)
enddo
Old   May 19, 2006, 17:18
Ananda Himansu
First Question regarding skipping first n lines of sequential formatted file to start reading on n+1'th line:
do i = 1, n
read(1,*)
end do
If the file is unformatted, the read statement above would be replaced with read(1)
Second Question regarding reading numbers separated with blanks but random number of numbers per line. "pc" has a good solution. In the special case where the numbers are all of the same type, and you know the total number "m" of numbers, simply use:
read(1,*) (u(i), i = 1, m)
Third Question regarding packed numbers with no separator. "pc" has the right answer.
Old   May 20, 2006, 11:23
zonexo
tks alot everyone. i'll try them a try!
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
