Problem..Help!!!!!!!
Old   May 23, 2006, 08:30
Default Problem..Help!!!!!!!
Vijesh Joshi
Hi friends..I am simulating the flow over a wedge shaped body using Ansys-CFX. The flow over the wedge is being Hypersonic(M5.75). I am neglecting viscous terms in the energy equation. I made the as blunt body with nose radii of 20, 40, 60, 80 mm one after the other. Now I was expecting the temperature on the surface of the wedge with sharp tip should be more than any other geometry. But the thing is being completely reverse....Plz help me. Regards VVJ.
Old   May 24, 2006, 21:17
Default Re: Problem..Help!!!!!!!
sunny
It will be better if you post this in the CFX forum, they can help you with this...
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
